How do i disable spark tip in for a 02 mustang gt EEC RYAF0T3 with hpt?
EDIT: OK under HP software i would setup like this
Tip-in Rpm Max> set to 100 ( you can Set this to Zero)
Tip-in Rpm Min> Set to 100 (You Can set this to Zero)
Tip-in Retard Airmass> Set Entire Table to Zero
Tip-in Retard Max Y axis> add below 2000 rpm addition value 1000rpm
Tip-in Retard Max X axis> i set 16, 384 to -3, 2000 rpm to -3, all the rest to -9
so i would leave the rpm enable/disable alone and just set it to remove 0 timing?
