Pre-VVT Hemi - Dialing in Fueling - VE Correction or LTFT+STFT?
Hello everyone, working on my 2008 Dodge Ram 5.7. Rebuilt engine and put in a new cam, so I am trying to get it to idle right and adjust so the fuel trims are closer to zero. Right now, it is pulling an excessive amount of LTFT+STFT. Even after pulling 20% VE in the idle areas, it is still pulling more.
It's my understanding that to get a good idle, I should increase the spark in the idle areas. Nevertheless, I am trying to get the fuel trims under control. I don't see a way to directly adjust fueling, but I believe it is done by adjusting VE. After logging a bit, I noticed that there is a VE Correction parameter. Should I be using 1-((VE Correction B1 + VE Correction B2)/2) instead of my current 1-((LTFT B1 + LTFT B2 + STFT B1 + STFT B2)/4) for corrections to the VE table? (I have it calculated that way so I can copy/paste into the VE Tables.)
I do notice the VE Corrections follow the fuel adjustments fairly closely, but I want to make sure I'm doing this the best way.
I'm also noticing the fuel trims for one bank is a few percent higher than the other, would that indicate an exhaust leak? Keep in mind I'm pulling fueling, so I didn't think it was that since it was still rich. Engine does have a tick to it, that does follow RPM, but I think it might be an error in pushrod length calculation on my part -- slightly too short. I scoped the exhaust manifold area with the tube-in-the-ear method and didn't hear any leaks.
Thank you for your thoughts!
