2016 Mustang Gt Whipple Stage 1 throttle blade not opening for WOT
2016 Mustang GT Manual trans
Whipple Stage one kit using Factory throttle body
Won't go into PE at WOT because the throttle blade isn't opening all the way.
KOEO TPS1 4.2v TPS2 .80v TPS2 .42 closed manually
With my snap on scanner hooked up I can read all throttle data
When i first turn the ignition on everything works and the throttle blades opens all the way when i push the accel pedal to the floor.
This will happen about 3-5 times if i keep pressing the accel pedal to the floor. Then all of a sudden it limits the throttle blade to 43%
I can't log anything with the VCM scanner i'm waiting to see if support can fix that problem.
I have been talking to Whipple support as well to resolve this i'm waiting on answers from them.
Just wondering if anyone has had this problem before?
