So i was trying to flash this car, the original ECU i could read it without problems, he bought a new ECU and flashed it with a GM tool and now comes as if it was blocked
Attachment 142575
any ideas on how to get past this?
Attachment 142575
That's not flashed with a GM tool.
It looked like a MDI 2, blue box, the car works good but it wont let me open the tunes
HPtuners recognizes it as tuner locked. Not corrupt, not unable to open, locked.
A little confused. So after a SPS GM flash for new ECM, it runs and has no drive ability issues. It will communicate with a typical OBD2 scanner. When you go to read with the Editor and attempt to get configuration it won't let you or when you go for a read it times out, or no communication, or gives some form of error.
Or is it you are looking at your tune file without it hooked to the vehicle and it will not open on your PC/Laptop?
