2 Attachment(s)
2014 srt 300 comp cams 274
Alright well, where to start, I have a 2014 srt 300 and I am having idle issues in gear after driving the vehicle around, hunts for rpm and stalls out when stopped in drive or when switching to reverse or neutral, I've looked around for a thread with a similar build and no luck I just want a base tune so I can break the engine in not to thrash on it, the total build list is a follows
Comp cams 274
Phaser limiter
Manley springs and push rods
Manley forged pistons +1.75cc
And forged internals,
So far from the factory tune I've got it to idle on start up and will idle all day long I am wondering if any of you gents have encountered a similar issue
Also I am a green noob tuner
If you have any input it would be greatly appreciated cheers
*update*
I got her running pretty good now I adjusted my fling and my rpm tables, I based my tables off another vehicle that has has similar modifications but I am still finding that the idle is a bit high and after adjusting it doesn't seem to go down, I want to make the car lump at idle a little bit more also will attach the tuning file now
thanks
