3 Attachment(s)
2010 Camaro 3.6 Weird Ignition Issue and Possibly Maxed MAF?
Looking for some input on problem areas on this tune.
This car is a 2010 Camaro 3.6 LLT with the E69 ECU. It is twin turbocharged running approximately 7psi of boost. Currently running the stock LLT MAF in a blow through configuration in a 3" pipe (between intercooler and throttle body). It has upgraded return style boost referenced low side fuel system feeding stock high pressure fuel system.
I have a few areas of concern. Screenshot here.
Attachment 121321
First) Is this what the MAF looks like maxed? Just flatlines at approximately 12,000hz?
Second) Is the air load % dropping like it does because of the MAF maxing?
Third) What is causing the weird ignition timing between 2000 to 5000 rpms while at WOT?
Tune file and log attached here.
Attachment 121322
Attachment 121323
