Does anybody have any good starting point VE table for 5.3 form Tahoe on E38 PCM, 2bar SD OS, totally stock engine? Tried Tune Repository but no luck, also did not found on board.
best regards
best regards
Can't you just copy over the stock VVE into the 2 bar OS and have your stock starting point.
Of course you'd have to use an excel program to swap the numbers around to make it work with the 2 bar OS axis's.
You should be able to use the stock one and use Excel to transpose it and flip the axis around to make it work for the new OS
Attachment 79014
copy and paste VE tables from that to start
Thanks a milion.
Now if i set table in scanner of math parameter LTFT+STFT, rows and colums linke in VE table, will that work correctly with NBo2 to adjust table for cruise ? For WOT i know i need to go with WBo2.
Should i "Paste Special" by multiply ?
best regards
under the edit tab at the very top next to the file tab. select that and in the dropdown is virtual volumetric efficiency table
when u apply custom OS they give you blank VE
