1 Attachment(s)
Dod Delete 2010 5.3
I have just finished a dod delete on 2010 silverado 5.3
Complete dod delete kit with new ls3 non dod camshaft.
The problem im having is I have turned to no error reported 10, 11, 3400s but still getting the codes and it starts missing at idle. you can plug in the old cover and it clears up.
Trouble Codes:
P0106 - Manifold Absolute Pressure/BARO Sensor Range/Performance (Permanent)
P0011 - Intake (A) Camshaft Position Timing - Over-Advanced (Bank 1) (Permanent)
P3401 (Permanent)
P3425 (Permanent)
Im sure im missing something but need help finding it.
Attachment 113358
Those are permanent codes, and aren't current codes. No need to be concerned with them.
You'll need to disable the DOD in the tune and it'll run on all 8 cylinders.
Go to Engine---Fuel---Fuel saving---and set DOD to disable
Thanks guys. I had thought it was turned off, but realized i didnt.
