Question for the Experts: E40 Electronic Fan Clutch
I have a very unusual project. I won?t bore you with the details, but it is an E40 ECM running a non-LS engine.
I have two potential problems. The first is that I am using a non-electronically controlled transmission. I understand that the SSR tune can be set up to run a manual transmission or in my case and non-electronic automatic transmission.
The second problem I have is that I was planning to use the electronic fan clutch from the Chevy Trailblazer.
I have the wiring diagrams for both vehicles. The issue I think I may have is that if I use a base tune from the SSR, it will not be set up to use the trailblazer type fan clutch. If I use the trailblazer tune, it will be set up for an automatic transmission. I know that HP tuners will allow me to select an electronic fan clutch as an option, so I?m wondering if I can use a base tune for the SSR, and then just change the type of fan in the software and then wire it like the trailblazer. I?m kind of stumped here and I really don?t want to go to electric fans if I can help it.
Any advice would be appreciated .
