Hi, has anyone modified this file for this car? I want to share it.Attachment 98135
hi,
yes increase the smoke limit in the main injection limit and increase the boost by 10-20%, increase the fuel pressure and raise the pressure limit maximum, once you are done with those three you can try adding negative timing in max soi table
you can add more vgt duty cycle to get the turbo to respond better
Thank you for this information.
