Anyone know what these row labels represent? This is on a 13 Dodge with a 65RFE. TIA
Attachment 102109
Attachment 102109
Maximum shift pressure per shift pattern
They all pretty much get used. I can post later what each one is.
Top to bottom:
1-2
1-3/1-2prime
2-3/2-2prime
2-4/2-3
3-4/2prime-3
4-5/3-4
5-6/4-4prime
4-6/3-4prime
3-5/2prime-4
4-2/3-2
4-3/3-2prime
4-1/3-1
2-1
3-1/2prime-1
3-2/2prime-2
5-4/4-3
6-5/4prime-4
6-4/4prime-3
5-3/4-2prime
N-1
N-R
R-N
I would set everything to 180psi except for the one that?s at 250. Don?t set the others above 180 unless you have a build transmission.
The max pressure limiting factor would be more to capabilities of the pump to build higher pressure and the valve body separator plate holding the pressure and not leaking, or so I would think.
