1 Attachment(s)
Need help with idle issue when shifing.....
Tuning a P59 in a rock crawler. Been fighting with this for some time. Engine is a stock 5.3 with mild-medium cam. 400 Turbo trans and stock converter. Still tuning in speed density mode. MAF disabled, STFT and LTFT disabled, Getting close on the VE table. Tuning with AEM wideband coming through the AC pressure sensor. Torque management disabled.
This issue I'm having is this; when going from park to any gear (R or D) my rpm drop to almost nothing and then surges back to stable. Going from in-gear to park, idle surges up and then stabilizes. Going from R to 3, almost dies and then surges up, lurching the jeep in whatever gear i went into.
I can't for the life of me get this fixed! Can someone take at look at this tune and give me some ideas? Thanks so much for your help!
:banghead:
Attachment 97788
1 Attachment(s)
UPDATE - converter installed
UPDATE -- Still need help!!
Okay, I installed a B&M 2400 stall converter to loosen up the trans at idle. NO MOSS!! Still have the SAME problem. I am about ready to give up. I have no idea what is going on. I have tried a hundred different things and nothing seems to make a difference. It seems to do better when the engine is cold, but the more it warms up, the worse it gets. It's to the point it will die almost every time I go from drive to reverse, or from park to any gear. I've posted my most current attempt at fixing it.
I'm at a total loss at this point. Can someone give me some insight please? Thanks.
One thing I forgot to mention is it does not do this when it's cold. Shifts perfectly then.
Attachment 99270
