We are compatible with late model windows operating systems such as window 7, windows 8 & windows 10.
I'm having trouble getting the vcm software to install on my surface pro 4, i keep getting this error:
Attachment 76656
can anyone help me out please?
anyone?
choose a different installation folder, i guess, has nothing to do with the device.
tried that. anything else?
I use Bootcamp in my MBP. Has anyone tried it using a VM like VM Ware under OSx?
it works but it was just lagged too much when scanning
I know this is an old thread - but hopefully, someone hunting for MacBook and VM finds it if they get this issue...
I have a new Macbook pro and run VMware, and it works like a treat until I installed ver 12.1. things tend to go a bit screwy if you tick all the go-fast boxes. The edit is always fine, but the scanner gets locked in a loop refreshing the screen if you have it on the laptop, but it works fine on a remote monitor. (ie on the bench, then in the car)
The root of the issue is Macbooks have two video cards, the internal one is a bit lower spec than the external one. If you tick Accelerate 3d Graphics under Display options, then it loses the plot and becomes unstable. Once you drop this option life goes back to normal and tuning becomes fun again.
I couldn’t figure out what was going on. I knew I updated at some point and Scanner had become unbearably slow. I actually bought a windows laptop to use instead I was so annoyed.
Hopefully this solution helps anyone else using VMWare.
I am having trouble using the Parallels for my Mac. I can't get the network connection. Any advice would be appreciated.
Anyone got HPT running on Parallels, with the new M1 Max ?
I have an ARM version of windows, which seems pretty good, but HPT wont launch.
Here's the App Log
Log Name: Application
Source: Windows Error Reporting
Date: 11/7/2021 5:51:26 PM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: xxxx
Description:
Fault bucket 2205772256468625838, type 1
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: VCM Editor.exe
P2: 4.11.587.0
P3: 61860760
P4: clr.dll
P5: 4.8.4420.0
P6: 6109cc1b
P7: c0000005
P8: 004d54da
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. c6f9fcee-e094-439c-8b20-a58fa87bc7f4.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. f288a5d2-2dc9-4c24-9044-5c57a81c7a42.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. 63903885-9057-4f89-9497-ae637f956664.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. cac7aaca-e059-4d1f-b29d-6f851d11bb3d.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. dfc7449d-6cbc-4d20-b1e9-db8c2fdf6e47.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArc hive\AppCrash_VCM Editor.exe_db1a54538bc4271ac6d21468ec718974de2a6da _f56dcd94_5a94d79e-3232-4ec4-985b-3dc8f3f52ad8
Analysis symbol:
Rechecking for solution: 0
Report Id: c1d48d45-d7f9-4e8c-b21c-431e273ee112
Report Status: 268435456
Hashed bucket: e74dfda4d03da52c4e9c7a2e3a3969ae
Cab Guid: 0
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Windows Error Reporting" />
<EventID Qualifiers="0">1001</EventID>
<Version>0</Version>
<Level>4</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2021-11-08T01:51:26.7784125Z" />
<EventRecordID>240</EventRecordID>
<Correlation />
<Execution ProcessID="6988" ThreadID="0" />
<Channel>Application</Channel>
<Computer>xxxx</Computer>
<Security />
</System>
<EventData>
<Data>2205772256468625838</Data>
<Data>1</Data>
<Data>APPCRASH</Data>
<Data>Not available</Data>
<Data>0</Data>
<Data>VCM Editor.exe</Data>
<Data>4.11.587.0</Data>
<Data>61860760</Data>
<Data>clr.dll</Data>
<Data>4.8.4420.0</Data>
<Data>6109cc1b</Data>
<Data>c0000005</Data>
<Data>004d54da</Data>
<Data>
</Data>
<Data>
</Data>
<Data>
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER. dfc7449d-6cbc-4d20-b1e9-db8c2fdf6e47.tmp.txt</Data>
<Data>\\?\C:\ProgramData\Microsoft\Windows\WER\Rep ortArchive\AppCrash_VCM Editor.exe_db1a54538bc4271ac6d21468ec718974de2a6da _f56dcd94_5a94d79e-3232-4ec4-985b-3dc8f3f52ad8</Data>
<Data>
</Data>
<Data>0</Data>
<Data>c1d48d45-d7f9-4e8c-b21c-431e273ee112</Data>
<Data>268435456</Data>
<Data>e74dfda4d03da52c4e9c7a2e3a3969ae</Data>
<Data>0</Data>
</EventData>
</Event>
