2 Attachment(s)
Turbo 408 Stroker w/E38 ecu swapped Nova leaning out past 5000rpm.
Car:
1973 Nova
Gen IV LS3 swap with E38 ECU
408 Stroker
Twin AEM 400lph pumps 8an feed to pumps, 8an feed to rails, 8an cross over line, 6an to the regulator, 6an back to the tank
Bosch 210 injectors
VS Racing 80mm turbo kit
Holley Hi-ram
102mm billet throttle body
4" MAF housing
I've attached the logs. The tune is very rough I know. The car leans out above 5000rpm. I notice that the IPW does not increase past 5-5.2ms as well. I figured this was from draining the rails so I have the fuel pumps more oomph by direct wiring them and removed the check balls from the feed line but the issue remains. Any insight into this?
Attachment 90081
Attachment 90082
