Anyone?
I would like to compare it with this one. Especially part-throttle timing.
Anyone?
Here you go. Attachment 103687
Thank you!
so i am having some driveability issues with an eforce tune on an lt1
long story but the guy who tuned my car says HIS torque tables are all wrong and want me to pay to retune.... something about not having the tools to access these table when he tuned car...
is there a way to cut and paste someone elses tables into my tune to see if it helps?
i know this is not enough info but if wot is good and lambda is correct then is there any danger in cutting and pasting those table into my tune or does it affect too many things?
don't want to go back to him as i feel that is not a good way to do business
my issues are bad cold idle
part throttle surging and once in a while ill get 80 to 100 percent throttle opening when pedal is like 30 to 40%
according to his dyno im making like 585 whp
mods are eforce 2300
1 step colder ngk
1/78 ltubes with guessi cats..
lt4 injectors lt4 hpfp and in tank pump
jms bap
rotofab...
^ you need to post your tune for any help
ok cool
changed name of tune so as not to badmouth tuner
also here is a log of bad cold idle
and one with the surge, hesitate anomaly..
forgot to add unmodified 95mm t/b to my list of mods
car is an m6 not auto
the one labeled slip then bang has a different value for throttle body i had someone plug in stock tb settings and then i logged with stock t/b to see if that was it but still does the same thing..
Attachment 104291
Attachment 104292
Attachment 104293
bump--
any help much appreciated
don't know where else to go for help
^check PM
