I was wondering if anyone had a file from the GM Performance LS376/525 Controller Kit I looked in the tune repository but it lists everything for year make model.
Did you ever have any luck getting a file? If not I was wondering if you could held me out a little. What is the base running airflow number you came up with for 70-80 degrees? I could use it as a start point that I would be seriously greatful for the help.
Thank you.
I have a 2006 CTSV file that was my 6.0L with the ASA cam in it. It will be a little different but just start with your stock cal. Add 20% to the MAF and remove 10% from The VE table to start with. Run your idle air around 16 to start with and install wb and go from there.
