Help setting up multiple AFR500v2's
I started with a single NGK AFX on input 1 for bank 1 for a decade, then I added a AFR500v2 on input 2 for bank 2 a few months ago so I could compare both banks. Due to the slightly different logic, I replaced the AFX with a second AFR500v2 a few weeks ago. In the channel layout, I changed the transform for input 1 to use the AFR500 (even though it's technically the same as the AFX), and the lambda readings in the two channels are expectedly different.
1) In the Chart layout, I previously had an entry for the AFX and the AFR500. When I change the AFX parameter to AFR500v2, the chart graphs became exactly the same. Is there a way to distinguish between the same type of wideband controller on multiple inputs in the Chart area? Is there a better way than telling the Channel that input 1 has an AFX on it?
2) In the Graphs layout, for the VE/MAF graphs that reference EQ ratio error. How do I know against which controller the EQ Ratio value is derived from? Can I change which controller the EQ Ratio references?
Thanks!
