L77 swap won't start. Runs on starting fluid. Seems like injectors aren't pulsing. I disabled both VATS and the starter diagnostics. Write All on flash. Is there something I'm missing on the tune file?
You did a Write Entire or a Write Calibration?
Write entire to both engine and trans. Is there something I missed?
A write entire is needed for the VATS removal. That is why I asked.
You can double check the file in the car to make sure, do a read entire of the PCM to make sure the VATS is off.
