1 Attachment(s)
2010 Camaro L99 engine and trans swap- Start then Die -VATS turned off
My first reprogram and hit a wall - I have read through so many posts and tried many things - I give up and here is the file I have been using - Engine trans and ECU are from 2010 Camaro - We are leaving it stock with no mods as it is in 55 pickup - Just wanted to turn off all unnecessary components - We are getting a P0107 map sensor code - U0109 Fuel pump control module - which I believe is disabled - and a U0100 ecm/Pcm communication error.
Thanks much for any advise in this matter
