I tried adding channels to scanner and cant find ones for e85 aka alcohol % on a 2019 mustang
tried using beta and base
Bump why do I have it for my GM. But not for my ford 2019 mustang ?
I know with my 2014 Mustang you need to turn ON flex fuel in the calibration for the pid to show in the scanner, likely the same on your vehicle.
Ok thanks for reply tried on GM scanner works. Go to ford have tune in car and running on e85 . Won’t let me add it
ok did update with latest version and now timing don't work
why are new updates making it harder to tune car ?
If you haven't, re-poll for supported parameters while connected to the vehicle. It's good practice to do that anytime you update the software or after you disconnect and reconnect from any vehicle. It often stops weird problems like this.
how do u re -poll ?
wow thanks for help found poll and it fixed problem thanks a lot good info
