4x crank trigger vs 24x crank trigger
Still learning my way around this stuff, and not yet tuning anything.
Can a stock tune for '99 Tahoe 4x4 be used in an L31 crate motor - if I have changed the reluctor wheel to a 24x ??
I don't have to change it to a 24x, as I just want to get the motor running and learn to tinker with the tune.(currently has 4x wheel in it)
However, in future I may want to use the 0411 PCM (may even start with this) in order to us LS1 type ignition setup and individual coils.
THIS I am told will require the 24x reluctor on the crank, and perhaps a different crank sensor.
The motor is NOT yet in the vehicle, and I will be putting a cam in it in the coming weeks. I just know now would be the easiest chance to put in the 24x wheel and save me a lot of work in the
future if I do decide to upgrade ignition to coil per cylinder.
I have not yet purchased a PCM, so options are wide open.
I do plan to initially run the Vortec intake, new spider, and factory vortec distributor.
Any insight is greatly appreciated.
