how to tune cold driving
Hey guys,
I am having an issue with cold driving. On a cold start and immediate driving, the truck dies and the rpm's fluctuate 500 rpm up or down, rolling/ coasting. It is a stick shift. I feel confident in my VE is good. BRAF nailed down warm but cold maybe a little high because when I do the RussK, I still have start up air flow in my scan on the 68F cell. Where should I look next?
LS1 in C10 pick up
MSD atomic Air force
Stock LS2 Injectors
holley 102 DBC
4Inch CAI
LS7 MAF/ IAT
PRC 59cc Heads
BTR Stage 4 car cam
Patriot double Valve Springs
Manley Valves
LS7 head gasket
comp pushrods
ls7 lifters
long tubes
tr55's
3 inch exhaust
t56
4.10 Gears
Approx 10.5:1 compression
93 octane
its likely either your idle airflow settings, or open loop fueling is too rich/lean
however its hard to give any proper advise when you havent even provided a proper log, or your tune. If you want good help, atleast give us something to work with
what year LS1 and do the fluctuations change at all as the engine warms up? I forget exactly at what temp the LS1 kicks in to use the idle fuel trims, but does it do it the whole time or does it settle in eventually, also with that much of a fluctuation what do you have your idle RPMs in gear and in park set to?
troubleshoot it in two stages
1. just idling no driving
2. once #1 is stable then go driving it and tune that part (the higher RPMs can mask a vacuum leak and have you chasing your tail)
