2014 C7 Corvette with A6 6L80e - U0101 code
Was sitting in the staging lanes this week, loading a tune and was not able to communicate with the TCM. Nothing out of the ordinary happened, just happened out of the blue. The car is now in limp mode and stuck in 3rd gear. No gear indicators showing either next to the shifter. I've tried letting it sit over night with battery disconnected. Also tried removing both POS and NEG cables and connecting them for a couple hours to see if it would clear/reset, but no luck. I believe the TCM is a T43 and is attached to the valve body inside the tranny pan. Anyone ever had the large TCM connector come loose or have a pin back out, etc??? I haven't put it on a lift yet to check...just looking for ideas.
