2 Attachment(s)
640 torque limit 512 g/s limit, how to bypass or scale? log and tune attached
2007 twin turbo z06, methanol on 91, same car everyone has helped me with for the past 2 years, thank you.
You will see in this WOT log, I am hitting some hard coded limit. the torque goes flat and will not pass 640 and the maf g/s goes flat at 512 g/s. I went back to look at older runs and I have never gone past that limit, it always goes flat at both of those spots. I ran into something like this when using the 1 bar map that limited at 114.5 kpa and had to get a 2 bar MAP sensor which fixed the issue.
Do i need a different maf sensor?(my maf tables in the tune read past the frequency/limit it is showing)
is there a table I can adjust(I did adjust the virtual torque tables but same result)?
Do i have to scale tables down like i had to for my hard coded fuel injector limit?
Thank you in advance. Afterwards I might also ask about that lean spike when i first get on the gas, but currently concentrated on the limits.
Attachment 99938
Attachment 99939
