hey guys quick question is it possible to read and programm a 2016 scatpack with my mpvi pro?
or do i have to use an mpvi2? also i would need the smart access cable right ?
On the vehicle's supported page on hptuners website it tells you if you need an MPVI2 or not. the 16 scatpack doesn't require a 2.
You only need the smart cable on 2018 plus.
You do however need to send the pcm in for unlock prior.
You can read a locked PCM. No need to send it for un-lock prior to reading. BUT you will not be able to write it until it's unlocked.
Cool thanks for the heads up guys and just wondering if I get it unlocked does it include the tcm in it??
The TCM is not locked and can be programmed before the PCM is unlocked. I did it on my own 2016 Scat Pack.
I wasn't aware of this. Definitely will have to attempt trans tuning on a 15-17 some time.
thanks for the reply guys, just got the ecm back from modification service gonna give it a go tomorrow
