2 Attachment(s)
c6 ls2 twin turbo boost question - tune attached that has lived for 48k miles so far
first off, guys enjoy the tune- it has lasted over 10 years like this and 48k miles up to 12psi on 93/meth only.
on a stock bottom end, what is the limit of the ls2 in a 6l80 corvette.
current setup::
STS twin t04 turbo setup running a single m15 alky nozzle, speed density tuned, 13 degrees timing at 5200 and 15 at 6500rpm. boost is 15psi on 10gal 93/5 gal 110.
I don't drive the car much so adding 110 is not an issue for me. I don't get knock and ive seen 18psi the other night on a brief pull. 50k miles on the motor. 48k of those boosted on 10-12psi. just started leaning on it a little because I got bored and took it to an airport race. at the race I locked the converter on the log attached and man did it load the motor, but still no knock. I mean I though for sure it was going to bend a rod. car make right at 700rwhp on 13psi. any help is appreciated.....enjoy the tune
