Can HPT be used to force a DPF regen? I recently cleaned my EGR valve but the code is still tripped for the DPF. I have a 2012 Ram 2500 with a HO Cummins. It is still all stock.
Nope it can?t
I believe AlfaOBD would be the best option to force a regen.
I know my response is rather late, but I decided to share some ideas. It's possible to use tuning software like HPT to force a DPF regen, but it's important to note that this should only be done if necessary. Have you checked the DPF sensor and the diesel oxidation catalyst (DOC) to ensure they're not causing the issue? In addition to checking the DPF sensor and DOC, using the latest dpf cleaning technology can also help keep your filter clean and functioning properly. There are various cleaning methods available, such as thermal cleaning, which uses high temperatures to remove soot and ash from the filter. It's definitely worth considering as a maintenance option for your vehicle.
