subscribe and fav's!!!
Checksum Validation(Oversimplified)- Think of your PCM as a cash register, stay with me here! Values are assigned to peices of information. If degrees of timing are represented by nickles for example, and you add a few degrees of timing the "drawer" will be off by a little. It may still function, but if someone(dealership or EPA) performes a count they can USUALLY tell right away if something has been changed.
What is/are Alpha-N tables. I assume alpha numeric? I've heard of it's use to control some functions on earlier cars but what exactly would one of theese tables look like & how do they work? How do they differ from the tables I'm used to seeing with HPT?
ACT
its in ford speed density
Air Charge Temperature? (replaced one of those sensors once)
how is this thread not a Sticky?
This is incredibly helpful !:worship:
It is a sticky. Been one for at least a couple of years.
This list still does not cover all acronyms on the table lists. Is there a comprehensive decoder ring somewhere I havent found?
Also terms like "torque" must be a derived term since I dont think there is a direct measurement of torque how is it derived?
whats F/A and FA
Dic
Dic = Driver information center
F/A = fuel/air??? Where are you seeing it at?
Great thread.
Ivt?
INFINITELY VARIABLE TRANSMISSION , IN VEHICLE TERMINAL , INTELLIGENT VEHICLE TECHNOLOGIES , IN VEHICLE TELEMATICS , IN VEHICLE TECHNOLOGIES , INTAKE VARIABLE TECHNIQUE , INTAKE VALVE THROTTLING , IN VEHICLE TIME
http://www.automotive-acronyms.com/
New to HP Tuners and EFI. Lots to learn. Thanks..
What is TSS from the RPM limit table?
Attachment 68961
MPVI = Mad Power Via Internet?
C2c ?
Mta?
What is tip in/ tip out?
