Can you not control target WOT lambda on M156s?
I see target Lamba at Full Load Component Protect at .92 and I see a Lambda target table for some kind of temp Delta but Id assume this is only for part throttle and gets overridden at full load. Dont see where normal operation target WOT lambda is a thing?
Could possibly set it up to run at WOT in Component Protect mode (without cats on car) so it goes to a certain lambda? Or set it to run open loop at WOT and let it target lambda .83 say but ends up actual .80 lambda but looks like all the setting for this are in Engine Temp not RPM or load
