Hello everyone, I know more about tuning NA cars, but in BOOST tuning I know little, I've done a lot of research in other topics and the things that I found and know I will put the differences between My stock NA tune, And after installing the Procharger Tune:
1- Installing New map sensor (2BAR)
2- Changing the OS to 2 BAR
3- Decreasing the Timing on the spark table 1 degree to 1 psi
4- Increasing the VE table ( going for SD Tune)
5- Editing the Power and Boost Enrichment Tables
6- Installing new injectors 50lb, and editing the Injector Data (Before was 32lb injectors)
so let me guys know if there is any problem with my tune or something is wrong :(
Mod list:
GM Sierra 6.0 (Forged LQ9 block, with LS3 heads)
Vortech Procharger V2, Stock pulley 5-6 PSI
Kooks headers
3.5 inch magnaflow exhaust
50lb fuel injector
450LPH Walbro fuel pump
Cold air intake
AEM Fuel Pressure Regulator (return fuel style)
few other thins..
