I'm trying to setup the EIO for the senors and have no idea how to get it setup properly:banghead:. I have searched on here to see if someone else set one up already, but no luck. Just found out I have the same issue with my PLX Boost sensor.
The product link for reference.
EGT
http://www.plxdevices.com/EGT-Exhaus...7346002184.htm
Boost
http://www.plxdevices.com/Vacuum-Boo...7346002191.htm
Tech Specs:
EGT Sensor
Physical Dimensions: 2 x 2.875 x 1.125" (52 x 75 x 28mm) L x W x H
Technology: T.C. Amplifier with Cold Junction Compensation
Accuracy: ~5 Degrees C (~9 Degrees F)
Measurement Range: 0-1023 Degrees C (32-1873 Degrees F)
Analog Outputs: Linear 0-5V (Driving Current 20mA) *Output is capped at 3.3
Operating Voltage: 8V-18
Power Consumption: 0.3 Watts
Operating Temperature: 0 - 85 Degrees Celsius
Sensor: One K-Type Thermocouple
Enclosure: Extruded Aluminum
Attachment 55261
Technology: Active Sensor Control Technology
Accuracy: <0.25 PSI
Measurement Range: 30.5inHg - 30 PSI (760mmHg - 2.11kg/cm2)
Operating Temperature: 0 - 85 Deg Celsius
Sensor: 3 Bar MAP Sensor
Attachment 55262
