FGX cruise control problems after gear ratio change
I've got an FGX XR6 6 speed manual ute (non Turbo) with a close ratio 5th and 6th gear fitted and the cruise control has stopped working in 5th and 6th gear and works fine in 3rd and 4th. It appears to be speed/RPM discrepancy perhaps simulating a slipping clutch with the lower ratio 5th and 6th causing the cruise control not to engage.
I'm wondering if anyone's come across this before maybe with diff ratio changes and found a remedy for it? I've tried a multitude of different settings in speedo parameters without success and I'm at a loss to know what else I can try altering in the tuning program to hopefully fix it.
