Originally Posted by
Ghostnotes
I just tried another round and still the same problem. I can get my idle perfect, trims pretty much 0, timing steady at 17*, throttle good, torque matches. Take a small drive to gather error data, copy and paste special ,multiply by % and out the window it goes. I'd be happy to post up a video if someone is willing to help to see if in fact I am doing something wrong.
I am also getting boundary errors. If someone can elaborate on this maybe it would help me along. What is it checking it against? My rows and axis in the editor match 100%, my row and axis has been changed via the options in the VE editor to a 3 bar map. What else might need to be changed in the editor besides changing the rows and axis in the VE editor to match.
Here is what I did...
Changed out my stock MAP to the red label, adjusted my MAP characteristics accordingly, left MAP estimation alone along with the other settings AAP1,2,3 and it is set to NI-TIAP. Went to my VE table changed the options to 3 bar, copied row and column axis to my scanner to match then on to scanning.....
Am I missing anything anywhere?
