Problem starting up build 15 coyote engine for the first time
Hi, got some nut to crack here. We have a 5.0 build engine starting up for the first time. Engine hardly starts up but does not run on all cylinders. Pulling the plugs show normal ignition on Bank1, (Cylinder 1-4) whereas Bank 2 (Cylinder 5-8) plugs are all completly wet. Changes were Injectors from MU52 to 1050x, data is considered correct as to ID specs in the tunefile. Besides that no changes have been made to the previous known tune file. It looks like the complete Bank2 is affected. We discover no missfire sounds during engine operation, however gas smell is obviously present.
OBD Codes show:
P0345 - Camshaft Position Sensor A Circuit (Bank2) (Pending)
P0349 - Camshaft Position Sensor A Circuit Intermittent Bank2 (Pending)
P0390 - Camshaft Position Sensor B Circuit (Bank2) (Pending)
P0394 - Camshaft Position Sensor B Circuit Intermittent Bank2 (Pending)
Plugs are new and gapped properly on all cylinders. Cam position Sensors are in the correct location and seated properly, so do the front phaser solenoids. Double checked all wiring.
Anyone some ideas ?
