3 Attachment(s)
(Coyote Swap)2011 F-150/6R80 Surging and throttle staying closed durin shifts
I'm battling a throttle surge issue at partial throttle accel (probably when going into boost). I have big IPC errors, but can't track down if its spark, throttle tables, or torque tables related. As far the throttle staying closed on shifts, I'm not sure if this is a problem in the auto trans tables or something else, but the throttle is staying closed for about 1.5 seconds during the shifts. I have someone helping me learn a little bit but I'm trying to make a drag event in less than two weeks and want to at least fix my throttle closing on shift problem. I'm new to tuning and want to be able to make changes at the track myself and none of the well known tuners will help, that is why i'm doing this myself and you might see huge issues in my tune potentially. I have been reading the coyote cookbook and the tuning school ford beginners book. By chance, could anyone take a look at this and help point me in the right direction to resolve these issues? A little background on my setup:
Its a coyote swapped 2003 Mustang using the 2011 F-150/6R80 and PATS deleted PCM (not control pack).
I based my tune off the roush file floating around and made changes.
It has 11-14 mustang intake cams
VMP TVS 2.3 Gen 2
VMP Twin 67 Throttle Body
Roush 2015 Intake (110mm)
ID1050X injectors
Returnless fuel system set at 58psi
ARH headers
Mustang oil pump with upgraded gears
Here is the current tune and log files, one is a WOT shifting one and the other is the part throttle problems:
Attachment 94266
Attachment 94267
Attachment 94268
