Kenne Bell 168mm voltage issue
Hello guys. Dodge challenger 2008 srt8 +kenne bell 3.6lc, azn cam.
Issue we have that lowest we can go with 0.04V on throttle body, and if jump lower voltage car goes into limp mode and half cylinders gone(red thunder bolt shows off), need to restart engine. We need to try 0.02 or 0.03 voltage to check if we can lower rpm with that massive TB. check engine lights we disable because of low voltage, but how to disable that limp mode?lowest rpm we can get now at idle is approx 1100rpm and about 17 afr. Maybe there are another options?? Appretiate
