Hi,
Does anyone have a base map of a tuned 2017+ F150 on E30, or E40? Or maybe a post that I can read to see what I can play with?
Thanks!
Hi,
Thanks!
You need to take a read including your transmission file and post it.
I will make some changes for you.
Don't tow with this.
Adjust how ever you want, make sure your logging all the "source" pids and if you hit any limiters post your log and I'm we can figure it out.
Try not to blow it up...Attachment 100176
Thanks so much. I'll give it a shot and post logs.
Make sure you have a tested e mix and dont mix 87 octane in.
WOT feels jerky, not smooth. Thoughts?
Attachment 100182
On it. Thanks!
Lastplace are you enabling the factory flex fuel for this, or modifying the stoich to start with this? Sorry I would take a look for myself but I can't open the file (I'm using v4.4)
1/4 mile log. Still jerky at WOT.
Attachment 100225
A couple more logs
Attachment 100226Attachment 100227
First thing I notice that probably isn't helping it your target lambda, 0.74 target is overly rich IMO. Second after like 4th gear WOT your fuel source changes from power enrichment to cat temp protection, thus bringing target lambda down to <0.7 lambda.
I would try 0.8 lambda as a PE target to start, and bump up the cat temp protection limits to hold that throughout. Even 0.8 is on the richer side, but it should improve feel and bring you out of the injector limit.
This one feels smoother on top end. Not as jerky.
