AEM X-series Boost -> Pro link analog issues..
I'm attempting to add my AEM 30-0309 into VCM scanner. It's connected correctly to the Pro-link analog input wires. I've tried creating a user defined sensor with the math provided by AEM which gives an incorrect result in the scanner. :crazy:
Per the AEM Manual: psig = (3.75 * Volts) -1.88
The only way I get can VCM scanner to show anything is with the pre-defined "AEM 30-4406" transform. Which obviously is also incorrect but hey it's proof that it's reading something...? I had a similar issue with my 03-0300 wideband which is also connected to the pro-link. That was a matter of just adjusting the equation to correct the result. I'm betting the boost side is the same issue but there is zero documentation/discussion that I can find on how to convert the AEM equations into something that works with the pro-link. :confused::confused::confused:
