2 Attachment(s)
Issues after changing 5th and 6th gear with gear wheels on TR6060 at Camaro Gen6
Hi everybody,
first of all, I'm from Germany and my english might sound strange, so please apologize for this.
I have a strange behaviour after changing the gear wheels on a Chevrolet Camaro MJ2017 V8 European Model
The standard setup for the Gen6 for 5th gear is 0.74:1, for the 6th gear 0.50:1.
What i did - and have done for the Gen5 about 30 times without any problems - is, i took the ZR1 5th and 6th gear wheels and swaped them against the original ones.
Now the gearing is for the 5th gear 0.81:1 and for the 6th gear 0.67:1.
In addition we changed the gearing ratio in the ECU by entering the new ratio in the schema.
5th gear is working without any problems, but 6th gear is causing a power reduction and a short time engine emergency mode if i push the gas Pedal more than about 10%.
It further indicates too much slip @ the clutch - which makes no sense in 6th gear. (a picture with the German Fault Code in the display in the notes)
Attachment 73287
Direct Translation of the Picture:
Action required
Reduced power
Reduce clutch engagement
So the 6th gear is not really usable....
Do i have to change any additional tables / schemas where the gearing has to be adjusted?
Attachment 73288
Looking forward to your thoughts and recommendations!
regards
Thomas
