Please provide a way to filter out transient states. A TPS filter that could filter out data when the TPS moves x% in x amount of time would be helpful.
already on the to do list.
Yes, but WHERE on the to do list? You and I both know that their "to do" list is about eleventy-billion miles long...
which one do you want more? autotune or transitional filters? make up your mind damnit! lol
I want both, as well as a baked potato on the side!
:D
(a burrito wouldn't hurt either)
Don't start with the burrito's again...you already got that months ago :yay:
I want RTT for LS2 A4 please.
What are they working on?
Just keep the Autotune on track , transitional filters n baked spuds can come in the next release :secret:
It's different for every controller.
For filtering transitions, it's basically saying 'ignore everything 500ms before a throttle movement greater than X, and ignore everything 500ms after, too'. But which numbers make it work depends on if you're gen 3 or gen 4 or cable TB or ETC, it might even change by platform/year/OS. You just have to figure out what you want included and what you want excluded, and then go through the parameters and find what will make it do that.
also if u run just the filter maths in the chart v time it will show 1 or 0 (true false) so u can overlay that with say WB data and see when its using the data or filtering it out, that way u can visually see what ur changes to filtering are doing, just set the range to -0.1 to 1.1 so u can see when its showing the 1 or 0 line
