2 Attachment(s)
5.3 m6 segment help
ok, i had m6 segment made by hp tuners support. finally got swap running and the vehicle will not accelerate over 2100 rpm.
swap is a 2002 silverado pcm/5.3 dbc with th350 into a 86 c10
also i went thru dtcs and disabled all the ones i dont need anymore EVAP, keeps setting 3-4 codes
i ended up using the pre m6 segment swap tune and unit runs great.
removed VATS disabled EGR and went thru and disabled dtcs and after a short drive to verify driveability issue is gone about 20 codes set for trans even tho i disabled them in the list.
can someone look over the tune and the data log and let me know whats wrong.
btw the 02s are not connected to exhaust stream in either test drive.
thanks. Attachment 41418Attachment 41419
ok figured out the issue with dtcs.
can i get a copy of this tune for refs to help with my tune please
