2006 G6 GTP lZ9 stand alone
I am working on finishing up my E67, lZ9 harness in a rock buggy running a manual trans and had a few questions on the final connections. I am hoping someone here would have some insight.
Park/neutral signal, C3 pin 46, do I need to hook this up?
Starter relay coil control, C1 pin 56, is this my starter trigger wire?
Run/crank ignition 1 voltage, C1 pin 19, does this go to my ignition switch?
Accessory voltage, C1 pin 18, I do not know what to do with this.
Powertrain relay control, C1 pin 40, not sure on this one either.
Battery positive voltage, C1 pin 20, Is my main un-switched power?
Any help is greatly appreciated!
