Is there anyway to control or disable anticipated shifts in the ZF8?
what are you referring to? anticipating shifts?
Unfortunately it is not possible to deactivate them with HP Tuners (only with INCA - but, it would required an .a2l and project - only ZF or Dodge would have them). So, the only way would be to work on your current shifts.
Could you share which issues you are having?
Thanks.
DodgeBoy.
YouTube: https://www.youtube.com/@dodgeboy2785
to anticipate is to "look forward to" or to "guess"
*does your zf trans do that?
oh bullshit
shift situations, driver types, clutch shift types, and the rest of it are not guessed at or anticipated...
drive mode, counters, and accel factors all determine these
probably
you have a log of each?
It could be a couple of factors:
- Wheel slip
- Shift schedule
- FZNAB (feature tranny has)
- Default shift schedule
Please, share a log with me (preferred at: [email protected]).
Thanks.
DodgeBoy.
Depending on the tc also if it kicks on it has a shift map for when it is active just a heads up. On the boosted os stuff I have it shift early with traction control. I think stock it shift early but you can have it shift like the others but with the extra power its nice like in the rain and such if you don't want to tame the foot. shift map 26 on some of the few os I just glanced at. Its actually mapped like a street shift map so I tend to pull 1 to 2k engine rpm out up top and tapper down.
