Just purchased a MPVI2 set up to help with tweaking my S/C Tundra. i was wondering if anyone has the TRD S/C Flash available for me to use?
TIA
TIA
Did you ever find a S/C tundra file? Or does anyone have one out there?
Figured I would add to this thread instead of littering
Its in the Toyota section of HPTuners forum. Called Toyota Repository
is the file you posted the SC file with correct injector data? my mpvi2 gave me a base file from my strategy, and I am not sure if its the TRD file or not. I do not want to flash the truck and have a no start condition. If you can confirm that file will work for the 2011 S/C tundra, I will give it a shot.
I found and downloaded your file, looks identical to mine except for a few throttle/trans settings. just need to verify if its the correct SC injector data
@nitrobrain06 Is that base file for the supercharged tundra? or N/A? does anyone have trd injector data?
Thats the base file for the TRD Supercharger. Toyota calls it a "Calibration" Im not sure if there really is a difference between the years of 5.7 S/C Tunes. but then again im no tuner. just a novice
