Originally Posted by
danall
Thanks for the responses. I really do appreciate it.
In the channels list i have WB EQ Ratio 1 (SAE), i realize i can change to units to afr for that channel. Yes the WB by itself appears to be logging. The actual AEM WB interface in the channels list (x series UEGO (30-03xx) does "grey out" when i vehicle connect, i assume this is normal? When i say the wide band appears to be logging is i can get an eq ratio error that looks perhaps correct using the standard eq ratio maths. I reckon i can use the eq ratio error for adjusting the tables, it's just that i am familiar with the afr error method, and not at all with eq ratio error. So even if i change the WB units in the channels list to AFR, the reported error for EQ is correct?, I can't get any afr error math to function. That is what had me confused, even though i specify afr for units in channels list, i can't get afr error, but can get EQ ratio error that appears correct when compared to narrowband readings at the same freq (maf tuning)
i will try 07GTS suggestion also. I'm tuning a crate lsx376/480 engine, 2010 vintage, that unfortunately has a ls2 tune that i have been struggling with. I grabbed some stock ls3/480 tables to use (VE etc) but even those were waay off. Was hesitant to narrow band tune mid to upper rpms since the tables were so far off in the lower rpms so I've acquired a WB. It's just that all the tuning I've done with narrow band was using afr error.
