2 Attachment(s)
2011 Mustangy 6r80 1967 Bronco Swap WOT Shift issues no power
(EDITED Attached Tune, and Log Files) iHi everyone, Im running into a problem in my 1967 Bronco Coyote swap with a 6r80 Transmission. At WOT from a stop I have slow to no power. However if less than half throttle it shifts and drives perfect!... It seems like the throttle body is shutting down itself. or if the TC is slipping. I have put back the stock tune (2011 mustang) minus the N/V Base calibrations and other specs in the speed Category. I have changed the gears to 4.56 aswell. I Have no CELS, I would like some help diagnosing where my issues are. Before I data log a tune for you all to go over what are the Channels you would like to see datalogged. Thanks for all your help look forward to figuring this out!
