05 pre/post injection off
Hi im wondering if you guys are using the timing calculator to get the truck to start with pre and post injection off? I went in to all the tables to see if setting the tables/adders/smoothing and so on all to 0 then running a flat 10 degree timing table would work, but the truck doesnt start at all when i do it...
I can play around with it some more tomorrow but at 15 minutes per flash... if anyone has a tip to get it going i would greatly appreciate it.
Other then that this software rocks... From Smarty to this... is unreal... I went from smoking all the time and at idle... to perfect idle, no more pulsing from the ac or other factors, it makes more power now then it ever has.. and i havent even really started to push it much...
Anyways, PRE/Post... thats the thread. anyone??
ANSWER: Startup Timing under Diesel Injection Timing Flattened map to 10 degrees. Starts perfect now.
