How to log APP/ETC Voltages - REP Help - P59 - NA - SD Only
Been battling reduced engine power issues in my 05 Silverado for almost a month now - has been a P1516 regularly, but have received P0068 and P2135 - and I can't find the voltages for the pedal and throttle body to watch/log to see what the issue could be. Pedal percentages haven't shown any issues, and usually cuts off at idle - so i don't think I'm hitting the upper airflow limit, and table is maxed anyway.
Thought I had it fixed as I hadn't had it pop up in the last week and a half, but cut off at highway speed last night with cruise engaged, which is a new failure mode.
I threw a bunch of parts at it while on the Hot Rod Power Tour and after to try and fix and keep going, but nothing has fixed it. TB, TAC module, x-link, pedal. Wiggling the harness, connectors will not make it happen - eight pin connector at throttle body has been verified good. Redid all the grounds, added grounds, no change.
Setup is a 102 bbk housing with a gold blade Camaro actuator, X-link. Got REP with this TB and the regular 87mm gm truck TB that was on the truck for a year. Actuator on current TB was on 90mm gm TB for six months before upgrade to 102. Cam is healthy solid roller 241/249 @ .050.
Anyway, I'd like to be able to log voltages for pedal and throttle body so I can properly diagnose it instead of throwing parts at it and hoping. Any other help would also be appreciated.
Thanks,
Ryan
3 Attachment(s)
Thanks for the help so far, but I'm still not getting anywhere
I can't find brake torque management in my TM tabs. I can't adjust limits for 1516 - only can set limits for 1514 which are already set to 4.0. Engine cuts off at idle when cylinder airmass is way under that limit anyways.
The only thing that changed since original tune was I went with a high volt alternator/battery and went a little tighter on valve adjustment. I've gotten REP on both alternators/batteries and with looser and tighter valve adjustments. Driving style did not change as in most cases it cuts off at idle - not sure how my driving style would change stalling at idle. First time I got REP it died in traffic at red light after waiting a minute or two for light to change (had driven from Atlanta to Columbia SC that day with no issues earlier). Has given REP one time while driving, at cruise speed but not logging because I thought it had been fixed at that point.
ETC limit is ~28% at 0 pedal and when it dies and I have recordings ETC is at 18-19%
Attachment 135243
Attachment 135244
And brake torque management is set to zero in system options:
Attachment 135245
Really would love to fix this thing (without spending any more money on parts because good lord this thing is eating my wallet alive) as it's a blast to drive. Would love to be able to run it down the track and see where I'm at. Made ~454 rwhp and it's a shame it just sits around waiting to be fixed. Still haven't completed the nitrous setup because this issue has me worried.
https://www.youtube.com/watch?v=jZ-EOl_QXOU
Thanks,
Ryan
