Last I heard you guys had not cracked the code on the 62TE's controls. Is transmission tuning still out of the question?
Bill@HPTuners, you seem to be the guy that knows everything here. Do you know the answer or who does?
doesn't ring a bell so I assume we have no eta for it.
The answer is no. There are settings for the transmission, but nothing that can be changed for any benefit.
Pretty much all you can do is alter the limp mode temperature trigger, called "Skip shift Enable ECT". But that system is disabled by default on mine, so I'm not touching it.
Well, that's at least 10 other 5th Gen Caravan owners that were hoping for a fix to the 62TE's erratic 2-3 and 3-4 that will be disappointed when I report back that HPT can't help them. I was really hoping for a line pressure increase myself.
It's been 2 years... still nothing? Apparently the true speed limiter is in there too. Even with the speed limiter in the Speedometer table set well above stock, I'm still hitting the stock limiter.
Still nothing, sorry.
