Originally Posted by
yonson
I 100% agree the DD doesn't seem like the correct way, but until we have access to the parameters we need such as the actual or virtual torque tables, (from the looks of the coefficients we have access to, they will be virtual) "raping" the DD seems to be the only way currently... Is the cam you installed still a VVT cam? If it is still VVT you are going to have to tweak the VVT parameters, hopefully you got some baseline logs with the factory cam that you can compare to your current cam.
